There are 2 Models with Oilpump.
The TE610/TE570 with the old Engine (called Dino). It can be identified by the chain on the right side. 1999 there is a new Model, first called TE610E, the Dual (later, it was called TE610, the Dino TE570). The dual has the chain on the left side. Ony the Te610E (the dual) has are "real" Pressure-Oil-Pump, the Dino only has this "spitting"-Pumpe after 1999.
The Models TE250, TE450 and TE510 are having a real Pressue-Pump.
Aftermarket oilpump???
- Motorrad: TE 610 '95
hitalia_610
aftermarket oilpump
hi husky friends, i´m from argentina, and i had a lot of troubles with my conrod, and i really would like to find a solution, and that oilpump model would be great, put more new and detailed pictures, and add some specifications of where you get the oilpump. ill be really gratefull.thanks
