Seite 2 von 4
Re: Digitaler TFT Tacho für 701
Verfasst: 01.08.20 - 17:34
von ViennaDC
Hi Andrea,
Looking forward to his project, looks very good.
I have a few questions:
-) Is this speedo to replace the OEM or is it an additional display?
-) If it's replacing the OEM, are you loosing the total ODO information or is it stored in the ECU.
-) Are you using only information via OBD Bluetooth Dongle or in combination with the original wiring from the OEM Speedo.
Thanks and best regards,
Matthias
Verfasst: 01.08.20 - 18:57
von diaboGS
ViennaDC hat geschrieben: 01.08.20 - 17:34 Hi Andrea,
Matthias
Hi Matthias,
1. You can replace or add the speedo. For example now I have added it for testing. In this case you need a Y cable for some datas.
2. The total odo is stored in the ECU. Not possibile to access it.
3. No bluetooth (lag). Direct cable connection.
Andrea
Verfasst: 01.08.20 - 19:07
von Pezi
hi Andrea, is it possible to buy the SpeedoX? Delivery time? Costs? Shipping?
Verfasst: 01.08.20 - 23:07
von BRB
Pezi hat geschrieben: 01.08.20 - 19:07 hi Andrea, is it possible to buy the SpeedoX? Delivery time? Costs? Shipping?
+1
Hi Andrea,
nice to have You here!
Regards-BRB
Verfasst: 01.08.20 - 23:37
von ViennaDC
Pezi hat geschrieben:hi Andrea, is it possible to buy the SpeedoX? Delivery time? Costs? Shipping?
It's still in development.
Verfasst: 02.08.20 - 08:14
von diaboGS
as Matthias says, it is in the final stage of development.
not much is missing though
Andrea
Verfasst: 02.08.20 - 14:32
von MK_II
Is ja echt geil
I want to buy it too! :wink:
Verfasst: 03.08.20 - 08:47
von BerGaMont
Hi Andrea, i´m also interested in buying your Display! Would really appreciate to be part of your testers, early adopters!
Thank you :guit:
Verfasst: 03.02.21 - 19:53
von Krischan
Fyi bin letztens auf Instagram bei Aurora Rally wieder über den "SpeedoX" gestolpert:
https://www.instagram.com/p/CKJvcFnHjN7 ... 80yyf1h1ev
--> die wollen das Ding wohl vertreiben.
Schaun mer mal...
Gruß Christian
Verfasst: 09.02.21 - 17:25
von Bollo
Ob der dann auch ein E-Prüfzeichen hat?
Ohne leider sinnlos.
Verfasst: 10.02.21 - 22:18
von BRB
Bollo hat geschrieben: 09.02.21 - 17:25 Ob der dann auch ein E-Prüfzeichen hat?
Warum sinnlos?
Ich würde das Teil, Liquidität vorausgesetzt, sofort kaufen.
Gruß-BRB
Verfasst: 10.02.21 - 22:53
von Bollo
Ich würde mir jedenfalls kein Cockpit ohne die notwendige Zulassung dranbasteln.
Die Dinger gibts doch mittlerweile überall.
Verfasst: 05.03.21 - 15:39
von Hxlrm
Ich bring das mal hier rüber
https://www.ktmforum.eu/forum/thread/10 ... ost1716719
Cumpan jetzt auch mit Ganganzeige für Modell 19-20, Signal wird wohl vom Gangsensor abgenommen.
Verfasst: 05.03.21 - 21:49
von BRB
Jetzt warte ich noch auf den von Aurora und dann wird wiedermal Kohle ausgegeben :roll2:
Gruß-BRB
Verfasst: 06.03.21 - 11:28
von Matzek
Was hat Aurora denn vor ?
Einen Drehzahlmesser bräuchte ich eigentlich nicht. Aber mit Ganganzeige, wegen dem 7. :D Gang, ist das Ding eine Überlegung wert.
Grüße Matthias
Verfasst: 06.03.21 - 18:42
von Matzek
Hab bei Cumpan angefragt ob die Ganganzeige wirklich bei der 701 geht.
Ja bei Verwendung und Anschluss unseres neuen CUMPAN werden die Gänge während der Fahrt angezeigt.
Und das stand in der Antwort :heba:
Grüße Matthias
Verfasst: 06.03.21 - 22:33
von BRB
Matzek hat geschrieben: 06.03.21 - 18:42 Moin,
Grüße Matthias
Wenn jetzt die Anzeige der Drehzahl noch auf eine "analoge" Balkenanzeige umprogrammierbar wäre und der jeweilige Gang mit einer schön großen Ziffer erkennbar wäre... :fil:
Gruß-BRB
Verfasst: 06.03.21 - 22:49
von Bollo
So wie eins davon?
2021-03-06 22_47_18-CUMPAN _ Drehzahlmesser _ Schaltblitz _ Motortemperatur.png
2021-03-06 22_47_18-CUMPAN _ Drehzahlmesser _ Schaltblitz _ Motortemperatur.png (163.18 KiB) 4349 mal betrachtet
Bild stammt von der Berotec-HP.
Verfasst: 06.03.21 - 23:28
von Matzek
Verfasst: 07.03.21 - 14:53
von BRB
:Top:
Danke!!!
Die Version in der Mitte unten wäre schon für mich perfekt.
Ich warte aber trotzdem noch auf das Aurorateil.
Gruß-BRB
