Keihin FCR MX 41.5 HUSQVARNA 450-510-530 SMR RR
Verfasst: 07.05.14 - 08:47
Keihin FCR MX 41.5 racing carburettor for HUSQVARNA 450-510-530 SMR RR (left side exhaust)
410 Eur Worldwide Shipped!!
Assemblies:
- TPS (throttle position sensor)
- Cold start choke
- Hot start choke
- Oversize bowl drain plug
- Fuel mixture screw remote control
- Silicone vent lines
- Custom weld aluminum fluid overflow tank
- Velocity stack neck size ø 64.5 mm
- SS bolts
Mods:
- Fuel atomization improving type needle
- High flow main jet
- Air flow velocity increasing plate’s intake side ¼; ½; ¾
- Air/Fuel mixture velocity increasing plate exhaust side ½
- Throttle channel surface treatment
Jetting specification:
- Needle = OBELP 3rd middle clip
- Main jet = #175
- Idle jet = #45
- Starter jet = #72
- Leak jet = #55
- Main air jet = #200
- Idle speed air jet = #100
- Fuel mixture screw up to your needs
Assemblies:
- Cold start choke
- Hot start choke
- SS bolts
Mods:
- Main jet = #175
- Idle jet = #45
- Starter jet = #72
- Leak jet = #55
