Husqvarna TE310 problem
lowcxxx
Motorrad: TE310 '09
Beitrag von lowcxxx »
Hello!
I have a Husquarna TE310 from year 2009. It has a 4 stroke engine. I have some problems with it. I am going to describe the problem so you can understand my problem.
When I start the engine it always starts up in the first try with no problem. It doesnt matter how I start it, it starts normally. Then when I sit on it and drive a few meters when i gave it in the zero transmission, or if I press/push the clutch even a little, the engine just shuts off. Simply said: when i start to ride it, the RPM meter is just so low that the engine shuts down always. Than it starts up normally again. When i try to ride it, the engine just shuts down always.
Now one additional problem (I dont know if it is related to the earlier problem but anyway). Sometimes the engine does not start with the button mode, but with the kick start it always starts. And I dont know why but something is periodically interrupting the contact with the front light, Sometimes the front light is working and sometimes not…
I hope that you understand what am I trying to say here. For me this is very complex problem so I am hoping for some kind of solution from your side.
I am looking forward to your help.
Re: Husqvarna TE310 problem
Hi there
did you check the micro-switch at the clutch-lever? It seems to be an electrical problem
within the "security-devices"
To your additional problem: :ka: I don´t know :-(
Best regards
