Newbie in forum with questions!
Verfasst: 25.03.06 - 01:55
Hallo from Athens!
I just found this forum and decided to sign in! I have a 1999 Te410e that is currently out of commission after it suffered con rod damage after almost 60.000Km. Instead of just fixing it, I have decided to modify it to make it a little bit stronger. So I got the crankshaft, con rod, cylinder, piston and a complete head off a Te610e and I am now almost ready to install them. I have a couple of questions that maybe somebody could answer.
1) I am looking for a Steuerkette for the Te610e. I am told that the one from the Te610 (without the 'e') does not fit. Does anybody know how many links it should have, so I can find one from DID, or another chain maker?
2) I am also looking to replace the clutch plates (Kupplungsscheibe). Does anybody know if I can use the plates from the Te610 (again without the 'e') model? If not, do you know who makes clutch plates for the 'e' model?
Thanks for your help.
