question about TE410
Verfasst: 23.04.06 - 22:40
von gele
Hi , my name is Angel i am from bulgaria
i have Husqvarna te 410
i am trying to change my engine oil but i cant find the oil filter ?
here is pictures of my engine :
i think my husqvarna is te 410 1997
i have husqvarna manual (pdf file) and on the manual i find that my filter is :
i am not sure thet my motor has this filter
so i dont know how to change my engine oil if i dont find any oil filter ?!
Help my please , here in bulgaria husqvarna is not so popular !
Thanks !
p.s Sorry about my bad English ! :)
Re: question about TE410
Verfasst: 24.04.06 - 00:09
von Dual-Sport
Hello!
Your engine has no oil-filter!
Verfasst: 24.04.06 - 00:50
von gele
hi , thanks for the fast answer!
so my job is to drain the old oil and refill it with new one ?
anything to clean from oil ?
Verfasst: 24.04.06 - 18:48
von David
you should clean the magnet that cleans the oil from metalchips and also the sieve. You have to untie the screw that fixes the oiltube. You can see it on the bottom of your first picture.
Verfasst: 25.04.06 - 12:38
von Mr_Jones
Hi Angel,
I owned the same bike 410TE 1996.
On the right hand side you have to open the screw with the connected black pipe close to the buttom of the bike.
You'll see the one big screw on your first picture.
You have to to open the screw and the oil will leave the engine. Inside you'll find a metal filter. It looks like an "cigar" at the end of that "cigar" you will see an magnet with lot of metal flakes.
Clean that magnet.
May be you need a screwdriver to pick out that "cigar" out of the engine.
It's tricky.
On the left hand side you'll find close to the both exhaust pipes two screws together with a black plastic cover.
You see that black cover on your second picture.
Open these screws and clean the magnet on the black plastic.
I changed each 800Km the oil and I never used full synthetik oil.
You'll get in trouble with your clutch system if you use full synthetic oil.
Use just synthetic oil. :D
Notice:
Please check the forum for the german word "Werkstatthandbuch".
You'll find the download of an instruction manual especially for the 410TE/610TE  1995.
Inside you find detailed instruction how to repair your bike and also how to change your oil.
Good luck  ;)
Regards Mr Jones.
Verfasst: 04.05.06 - 03:19
von gele
10x a lot about all your answers , they ware very helpful. I change the oil last week.
Mr_Jones: i'll check for manuals , 10x about "Werkstatthandbuch" word ;)
I put 1,5L -  20w50 Motul oil.
