photo upload,how?
photo upload,how?
hi,i'm sure this has been asked and answered but translate sucks,how do you upload images,everything i try it says file is to large
,is there a way to resize images for upload without having to crop them to nothing,sorry if this has already been answered,my german sucks,thanks
* When you try to do something... nothing happens.
If you really want it to happen, you've got to do it.
Re: photo upload,how?
where is your problem.
The only thing you have to do, is to reduce the solution of your pictures. its not that difficulty!
It will work with Paint, Picture Manager, Gimp, or any other picture editor. If you choose a size 800 x 600 pixels it will work!
You can upload your pictures in your personal gallery or in your post.
Is the menu of this forum in german language or in english?
thanks,i'll try that,the menu is in german,translate program isn't that greathqv610 hat geschrieben:where is your problem.
you can upload the small pictures in size 800 x 600 pixel on the frame "Dateianhang hochladen" under the smilie bar ... click on "durchsuchen" and browse on your computer for the picture and choose it, then click the button "Datei hinzufügen"
When the upload is finished you find the file under the smilie bar too, just click "Im Beitrag anzeigen"
looks like this:
you can upload your picture in your personal user gallery, but to explain that in english is complicated ... a little bit
Just try it, it's not so difficult ...
looks like this:
That's it ...
@ Diktatoren ääääh Moderatoren ...
: Gibts diese zuerst genannte Vorgehensweise auch bebildert als Anleitung ... habsch nix gefunden
looks like this:
looks like this:
That's it ...
Marc hat glaub was aktuelles erstellt.... aber nix mit Bilder's .... ich gugge ma...
ach nee, des war des mit den Video's.... http://www.husqvarna-forum.de/viewtopic ... 18&t=43444
Aber Du hast des ja scho schön erklärt.... habe sogar ich verstanden...und des als Bayer...
- emti
- Foren-Hooligan
Hi Sm570nut:
Is this discription ok for you?
If it doesn't work, DHX77 will made an other discription with pictures. He comes from Bavaria. His german sucks, too! So he is the best partner for a picturebook - only for you!
Desmoquattro 4 ever
@emti your wish is my command.....
first Step
"Persönlicher Bereich"
next one
"Galerie"
it follows
"Persönliche Alben verwalten"
next one
"Bild hochladen"
and than...click on "durchsuchen" and browse on your computer for the picture and choose it, as well
it should look like this... and click on "fortsetzen"
the last frame looks a little bit crazy, the subareas doesn't work, the programming does not fit.....
the area with the green arrow shows you a preview of the image...you have to click on "Absenden"
you are finished....
the image has been successfully uploaded
the User Gallery looks like
Do you understand everything...????
I think it's easy...
@emti....
lick me....
I do not have pictures taken with the camera from the screen, just like you .... do you remember... ????
first Step
next one
"Galerie"
it follows
next one
"Bild hochladen"
@emti....
lick me....
DHX_77 hat geschrieben:@emti....
lick me....
I don't have pictures taken with the camera from the screen, just like you .... do you remember... ????
- emti
- Foren-Hooligan
Nice, nice! You are so good!
Ps: Shut up you Dödl!
Desmoquattro 4 ever
Nur mal so zur Info: der User "sm570nut" benutzt die engliche Board-Sprache. Und eigentlich geht es um die Bildergröße.
#206
hier schreibt er aber das sein Board Menu in Deutsch ist ... daraufhin hab ichs ihm ja erstmal versucht es ihm mit den deutschen Begriffen zu erklären ...sm570nut hat geschrieben:thanks,i'll try that,the menu is in german,translate program isn't that great
Dann hat er es umgeschaltet, denn in seinem Profil ist die englische Einstellung...
#206
- John
- Motorrad: Nuda 900; Berserker
Auch ein herzliches Willkommen aus Niedersachsen! Fahre eine 2013 Standard mit ABS
Hey Leute das mit dem hochladen habe ich ja gescheckt.
Habe das Problem das die zu groß sind 3,27MB ! Wie mach ich die kleiner? So das ich sie hochladen kann.
nimm ein beliebiges Programm zum Bilder bearbeiten.
Ich benutze sehr gerne Paint.NET oder den MS Office Picture Manager.
Du musst dann einfach nur die Auflösung auf max 860 x 768 Pixel verkleinern, das Bild zwischenspeichern und entweder im Beitrag oder in deinem Album hochladen. Is jetz ned sooo schwer.
Sehr freundlich! Dank dir. Hab´s hinbekommen
- CIMG2850.jpg (375.21 KiB) 29639 mal betrachtet
Schöner Donut
- dr.-hasenbein
- "der Dino-Doctor"
- Motorrad: SM570R Doc. edit.
wohl noch nie nen Donut gesehen ?
