Hi guys,
First of all, sorry for not writing in German, it's been a while since a last spoke it so it is better to write in English.
Second of all, I have 2004 Husqvarna 125 Sm which I recondition now and I can not find any information abut my 40 mm Marzocchis. I have the oil seal(can not find the dust seals) but I don't know how much oil i need to put in each leg of the fork. I also read about some problems regarding the bleeding of the cartridge but I don't know if this is the case.
Thank you for your Help!
Husqvarna 125 sm 2005 Marzocchi 40
- Motorrad: TE 610 '95
Re: Husqvarna 125 sm 2005 Marzocchi 40
This may help you:
https://husqvarnaoutlet.com/repair_manuals
No, unfortunately they don't have the manaul for 40mm but I got some info and it seems that 500 ml should do the trick. Thank you!
No data in the Workshopmanual for the 2004 125 SM?
No, but meanwhile I found this: http://marzocchimoto.blogspot.com/2013/ ... usd40.html
It is the workshop manual for my fork and I found out what I needed.
Thanks!
Thanks!
